im looking at wheel selections. id like to use my tires as i have the 16' toyota oem rims. but will buy new tires if i have to if i go with a 17' i am just concerned about getting the appropriate offset correct. i don't run spacers i will have the 2' tough dog suspension and springs. the ones im looking at are .i want to avoid rubbing issues at all cost.
which is better the 12mm or the 7mm offset ?
Fuel Wheels D600-Vector 17x9 Bronze -12mm Offset
4.75 backspacing?? 0 offset
Method Race Wheels MR305 NV Matte Bronze Wheels with Matte Black Ring MR30578558900
6 backspacing and 25mm offset, are 18s to big i want to avoid rubbing issues at all cost
Method Race Wheels MR305 NV Matte Bronze Wheels with Matte Black Ring MR30589058925
if i go with the 17' or 18 i will be going with the BF KO2s
thanks for your help i know theres a lot of threads and i read them all they all run off
Fuel vectors will not clear the hubs in the 100 series and -12 offset is way too aggressive .. So those are a big NO.
The 17" methods with a "0" offset are too aggressive as well - stock is +60 so you will be pushing the wheel out 60mm. Any 33" tire will likely cause a good amount of rub.
Plenty of guys run the 18" method with +25 offset and either 275/70r18 or 285/65r18 with little to no rubbing.
Nothing wrong with running your oem 16" wheels - they're great. Rattle can them if you want to change the look.
Good luck
