So here’s the deal, i just replaced my lower control arms with factory OEM replacements, and installed Dobinsons rear springs (C59-675V) if that matters, and aligned it.
Drove it to work to do the work in the AM; perfect no vibrations. Drive it home after the work and it has a pretty annoying vibration that starts at about 55mph. Seems to clear up a bit at 70-75ish but is still noticeable.
The tires are new and were balanced 2 weeks ago. The alignment is dead nuts on. I didn’t change the height of the front Radflo’s, only the rear height changed.
The only thing I can possibly think of is pinion angle? I have metal tech upper and lower rear links on order but they’re out of stock. Anybody have any similar issues after minor/minimal work? The truck is at about 2.5” of lift in the front and 3-3.5” in the rear.
