Will Van
GOLD Star
Edit: Do I need to install a new race with the spool and bearing? Or can I use my old one?
I picked up a part-time 4WD transfer case spool from Cruiser Outfitters, and I'm installing it this weekend. I've reviewed several different sources for how to do the install. I'm just documenting my progress here, as well as any questions that I might have.
Converting HF2AV Transfer Case into Part Time Transfer Case
DIY Transfer Case Fluid Change How-To
First off, what's the best method to break the driveshaft bolts loose? Two long open-end-box-end 14mm wrenches?
