David70FJ40
Older Than Most
Cruiser Outfitters is way out west, UT I believe. Shipping for the kit will be high, maybe over $200. Is there a retailer on the east coast?
Iron Pig Off-RoadCruiser Outfitters is way out west, UT I believe. Shipping for the kit will be high, maybe over $200. Is there a retailer on the east coast?
IPOR No thanks! I'll go without. I'll try TPI.
yes yes yesYears ago, after an exhaustive research, I put the 2.5" OME kit under my rig. And if I was buying another lift kit today, I'd purchase OME again thru @cruiseroutfit .
Here is what the 2.5" OME kit with 32x11.50's look like on mine.
Nice rig fareem. I’m leaning towards the pro comp. I think I’m going with 31s to give some more space in the wheel well. I can take the saved money and buy something more important - like seatbelts!
I think 33x10.50 at least, because it’s close the biggest stock tire size (9.00-15). Stock size 7.50R16 is also 32” tire.what's the biggest tire you can clear and ride on with a stock FJ?
If you put 33’s on a stock 40 you will rub the inner fenders as soon as you get off flat pavement. 31’s might work but will rub at extreme uneven trails IMO (45 years of ownership, tires, lifts).I think 33x10.50 at least, because it’s close the biggest stock tire size (9.00-15). Stock size 7.50R16 is also 32” tire.
