Just got done with a head gasket job on my 1994 1FZ-FE. I had the head rebuilt by a local machine shop and had both pans down to fix the rear arch leak. I ended up replacing the tension slipper as well. I also deleted the PAIR and EGR. I just got it back together and the timing done but it sounds so darn “ticky” when it’s running now. I used a stethoscope to check for valve clatter but I don’t think it sounds like the valves and they were just done. Also, I drove it for 30 miles around town and changed oil.(Conventional 5W30-30)
I’ve searched and it seems like many folks say that some ticking is acceptable. I can hear ticking from the fuel pressure regulator with a stethoscope. Does that equate to a faulty injector? Doesn’t an injector click a little anyways? What causes an injector to click louder than usual? Other than the ticking it seems to run great and no CEL so far (50 miles)
Thanks,
Ed
Thanks,
Ed
