I just completed a head gasket replacement on my 1997 80 Series Land Cruiser. The engine turns over, but won’t start. The truck was running before I started this project and has 220,000 miles. I did the head gasket R&R as preventative maintenance, and took the cylinder head in to my machine shop for surfacing and a valve job. Also re-sealed the oil pans and timing chain cover.
I’m getting spark, but no fuel in the fuel rail. I pulled the fuel return line off the fuel pressure regulator, had someone turn the ignition to the On position - no fuel.
Used a stethoscope to listen if the fuel pump under the rear seats would come on after the ignition was turned to the On position - no sound.
The EFI relay under the hood does come on with an audible click when the ignition is turned to the On position. Both the EFI 15A and IGN 7.5A fuses in the box under the hood are good.
During the head gasket replacement project, I disconnected the main engine harness from the ECM behind the glove box and pulled the harness through the hole in the firewall into the engine bay. Everything was reconnected when I reassembled everything.
I’ve not yet pulled the access cover to the fuel pump to test it, nor have I tested the fuel pump relay.
Does anyone have any ideas as to what the issue may be with fuel pump not operating and suggestions on how how I can resolve it?
-Paul
-Paul
