I have bleed brakes on just about every type vehicle. I've never had so much trouble as with my FJ40 this go round.
I replaced all the rear brake cylinders (2 each side). Also replaced the hard line that runs across the rear axle housing. Anyway, I have bled the brakes three different sessions, feeding three small bottles of fluid through the system and still the pedal sinks almost all the way down after the truck sits a few minutes. The system is really clean now and so I am recycling the fluid that comes out now. So it has been bleed, put that back in the reservoir, bleed.
I probably messed up in that I let the hard lines drip as I worked on both sides replacing the brake cylinders and getting the shoes back in place. So a lot of fluid came out of each line and am sure lots of air entered.
I started bleeding at the fartherist cylinder from the master cylinder. So I bled LR, RR, LF, RF. Kept going in that order several times, making sure to keep the master reservoir always full.
I am using DOT4, which I am sure you can use in place of DOT 3. Just not the other way around. DOT 4 has a higher boiling point.
I just ordered Russell 639560 speed bleeders (10mm x 1.0 thread) on Amazon. They will be in tomorrow. Am going to try those since the wife was getting bored doing the pedal pumping.
Any other tricks? I have heard people use some vacuum tool. Which one do people recommend?
Thanks for any feedback. Getting a bit frustrated.
