My fj62 had the 02 sensors further back. Yours look to be on the downpipes. Now i dont have hardly any seat time in mine but i put them lower in the stream
The pinging I experienced was with the now-dead motor that blew a head gasket. I haven't driven this one enough to notice pinging (that and it's really cold out). If I had saved the smog parts, I'd totally be ok with replacing them if I thought it'd solve this. When I desmogged it, I didn't see anything that indicated doing so would cause problems like this. :/
If that's the case then the motor I had originally must have had non-factory exhaust. I remember looking up tear-down photos to see where they were attached when I had a shop make the exhaust.
It's my understanding that the timing cannot be manually manipulated the way it can on a carbureted engine as the ECU will adjust the advance as it sees fit. 10:1 was just a guess. I need to get the O2 controller hooked up to a serial port on a laptop to do some data logging.
I liked it better with the Ozone sensorI mean, you have a wb o2 sensor but are guessing at the values it’s returning...
I'm not guessing at the values, I'm guessing at their average. The gauge reads a steady fluctuation of AFR from about 14.9:1 up to around 16:1... it just bobs back and forth at idle. But you're right; I need to focus on the basics first. I thought I had the TPS crossed off the list, then I realized I was running a '89-'92 TPS so I need to swap it out with the correct p/n and do it again.I mean, you have a wb o2 sensor but are guessing at the values it’s returning...
Also, I noticed something peculiar tonight - someone has drilled a hole in one of the spare AFMs I have.
Any idea why someone would do this?
It's my understanding that the timing cannot be manually manipulated the way it can on a carbureted engine as the ECU will adjust the advance as it sees fit. 10:1 was just a guess. I need to get the O2 controller hooked up to a serial port on a laptop to do some data logging...
I pulled the distributor tonight too and ran the diagnostics. It checked out fine.
Curious which FSM you are using and what’s the source of the 3FE? The 88’ manual is different page wise.
Reading back through your posts, My suggestion would be to step through the ECU voltage tests at some point soon. It will at least tell you if they’re at stock specs for TPS, AFM, and other sub components in the FI section.
I’m intrigued about a desmogged 3FE, I saw a few posts when researching other 3FE things just haven’t dug down on it. Seems you’ld almost require a reprogram.
You have some great minds that have posted above. I’m following this one for sure. I think there’s a lot to be said about properly desmogging an engine that Mr T designed otherwise.
