FYI
Fuel Cut RPM test?
And I found your previous thread about this problem.
3FE- Loss of power/mild stumbling/at mid RPM range (Fixed it Thread) Whew.
So, from a big picture troubleshooting view, you have the same problem with the new engine as with the old. This leads to the tentative conclusion that it isn't the engine. Which accessories or components are common to both your installations? Which sensors and VSV's did you reuse? Or possibly, what procedure did you do incorrectly or omit both times to reproduce the problem?
On my 62 it ran fine when I parked it, then, after rebuilding most of the braking system, it ran poorly. Made me think it was a vacuum issue and I chased all the usual suspects of hoses and intake without finding a smoking gun. I gave up for the winter.
It only stumbles under load and at exactly the same rpm range.
Fuel Cut RPM test?
