looks real clean, nice job.
no advantage weight wise since the fiberglass actually weighs more. (read thick)
the advantage is quieter, warmer, stronger, never rust.
I have been folowing your projects and find the thresds very interesting.
I am a great fan of diesel engines and I own a 1984 FJ40. I swaped a 1HZ(with the orginal 70 Series Trany) for a 2F.
I am curious to know what wheight advantage you can get from a fiber glass body as compared to a conventional Steel.
Following are the pics of my HZJ 40 engine bay.
Take Care
Whats the 40 go like with a non turboed 1HZ?
My 73 series was quite nippy for a N/A diesel when I had 32 in tyres and I think the 40 is a hundred or so kgs lighter.
Nice looking conversion,the 1HZ really is one the best bangs for buck.
It is great. Though I think my 1HZ came out of a HZJ79. That is what I think, coz gearing seems to be on the lower side. But the engine is in a great nick. It is very nippy and occasionally I do surprise people in traffic signal drags.
The best part is the fuel consumption. On motorways it returns around 11 Km?Liter, which comes out to be 25mpg.
P.S I am running 31/10.50/15s
hand formed rear brake line
60 series water seperator to clear any contaminates before hitting the fuel feed pump, this will have a warning light mounted to the dash.
the 12V feeder pump which supplies pressurized fuel to the injection pump, the improves starts and acceleration...
Walbro FRB-5Where do I source is this 12v feeder pump from?
@OtterX did you sell your rig? Hate seeing it on Mushro's site.
FJ40, FJ45 & FJ55 Toyota Land Cruisers Call 24/7 (313) 414-3540
Walbro FRB-5
It doesn't do anything except cover up faults such as air leaks and worn out injection pumps feeds. All my diesels have started instantaneously without it.
You can not "pressurise" the fuel for better starts, its nonsense. Any extra pressure on the low pressure side of the pump means the bypass valve will open and send it back to the tank. If you did add pressure to the low pressure side, the pump would eventually leak like a sieve.
The pressure on the injection side is 4000-5000psi at the injectors, a little 7psi pump on the fuel line will not make any difference. And in any case, its the adjustment or shimming of the injector that regulates cracking pressure at the nozzles.
Injection pumps typically use only a 1/3 or a 1/4 of the fuel that enters the pump. The excess is recycled back to the tank or filter depending on the type of pump. It hardly needs more fuel.
