That thing looks good man ! Is there a reason you spaced the winch mounting up above the frame rails ? Do you have your own plasma table or was it hand cut ?
..... plasma table or was it hand cut ?
.....From the looks of the pic with all the various parts laid out I am pretty sure this was not cut freehand.
I would bet the higher winch mount placement is to allow for the tapered lower section: improved approach angle. Looks good. From the looks of the pic with all the various parts laid out I am pretty sure this was not cut freehand.
Looks awesome! I have been itching to ditch my Ironman and build my own front bumper. With the way you notched the frame, do you think a smaller winch could still tuck in down lower?
Before welding, I made sure the LED light bar fit behind the hole I made for it. All is well.
I welded both inside and out of each joint, which took approximately forever. I then ground down the outer welds, rounded the corners, blended and smoothed the whole thing. This took an additional forever. This dustpan is all grinding dust swept off my table, and the floor under it.
Put it back on the 80 to verify clearances for the winch and the fairlead mount.
And also add a tube to the top.
Assembled the laminated tow points and welded them on. They consist of a 1/4” layer in the middle, then 3/16” on each side of that, all wrapped around a chunk of 1.5” .250 DOM.
Took the bumper to be blasted and powder coated Carbide Black, which is a lightly-textured finish I also used on my rocker guards and my 4x4Labs rear bumper. Here it is today.
Peek-a-boo, the LED light bar. If you look close enough, you can see the “hood” I welded in to fill the space around the top and sides of the light bar, since the face of the bumper is not vertical.
Great design - well thought out! I’ll take one...Before welding, I made sure the LED light bar fit behind the hole I made for it. All is well.
