hey guys,
Still only 7 months into owning my 2014 LC, so I'm learning more every day, and have two questions for you.
First, how long do you let it run after you start, before you put it in D (or R)? On my old car, it would rev high for 10-30 seconds and then drop to idle, and I knew I could shift then and it would be fine. In the LC, it sounds like the fan runs real high for a few seconds. I usually put it in gear after that, however....
Second, once it started getting cold, it will occasionally lurch into gear. Sometimes not at all, sometimes really violently - even with the foot firmly on the brake, the whole truck will noticeably move. These lurches are accompanied by an engine rpm spike. The problem is, it doesn't always happen, it's only on cold starts, and it doesn't seem to matter how long I let it run before shifting. It also doesn't matter how fast I move the shifter (I thought it might, for some reason).
Any thoughts? I don't want to wait for warmer weather for it to go away (assuming it would).
