- Thread starter
- #101
Standard cam break in procedures to keep the cam lubricated.
Anyone know or could measure for me how much valve tip depth there is on a 1FZ-FE head? Thanks!
So, it looks like speaking with Schneider Racing Cams they are recommending the Supertech lash caps and the depth will have to be ground to fit the valve tip on the Cruiser as they are made to a 3mm depth and we need around 2.25mm. I will know more on this after the valve job.
Yes you did! They just recommended the lash caps, not the cam followers.
If I understand them correctly this is the recommendation. Lash cap under stock bucket and stock shim. They say the Supra guys are doing it up to 8500 rpm with no problems and they grind more off the bottom of the lash cap than I will have to.
If I get a larger shim on top of the bucket, I will risk it coming out.
I agree, it's not ideal but it's not clear at this point whether Supertechs cam followers will have the size I will need. Waiting on the machine shop for final measurements.
What I really want is a shimless bucket, but the machine shop wont grind the Nissan ones where they meet the valve because their hardened. So, that's a no go. I'm not aware of any other shimless buckets that could work.
I could go with a longer valve. It appears Manley has one that's 1mm or so longer than stock. Might be nice for my supercharger, but spendy.
Lots to think about. Decisions, decisions, decisions. Thanks for all of the help!
All I can do at this point is wait on the machine shop and see where I'm at when the time comes for the turtle build.
The other part of that equation is how tight or loose to set the valves. What's your thought on valve clearance with aftermarket cams? Schneider recommended anywhere from 0.008 in/ 0.010 ex to 0.014 in/ex.
Well I actually beat Schneider to the punch recommending Supertech and that 3mm depth is not entirely true. You buy a formed cam follower with a place on the underside for 8mm cam follower shims. The bare cam followers are 2.70mm, 3.25mm, 3.28mm, 3.78mm, 4.20mm, 4.80mm and the cam follower shims are 1.35-3.50mm.
Looking at this mud page: 1FZ engine building and blueprinting, it's showing the diameter of the buckets at 34mm. On Supertechs cam follower page: Cam Followers, it's showing available bucket depths in the 34mm size at 2.5mm, 3.5mm, and 6.5mm. Shims 1.35 to 3.50mm. What chart are you looking at to get your data because that would give me far more sizes to work with. Thanks again!
Reading some threads it appears the stock buckets may be 2.95mm thick plus shim range of 2.5-3.3mm. So, 5.45-6.25mm total OEM range.
With a .080 base circle regrind, it appears I will need around 6.45-7.25mm. The valve job can give .010 (.25mm) back in height though. My concern/interpretation of the chart that made it sound unsure is that the 6.50mm cam follower with the minimum shim would take me to 7.85 and the maximum 3.50mm would take me to 7.00mm so if I needed above 7.00mm to 7.25mm that might be an issue. Maybe I just answered my own question of the valve job potentially making 7.00mm the max I'll need.
The other thing is that the machine shop likes to set this up on the bench prior to me torquing it to spec on the block. My understanding is that valve adjustment can change some once bolted down. How likely is this with having the head and block surfaced?
