Nice, that's a great update. Within the last year I've changed just about everything on my front end (suspension, sway, steering, brakes) and it feels so good now. Absolutely worth it, considering we're nearing 20 years of age.
Dang you're gettin after it! Not a better way to learn every part of it though! I was actually wondering about wire harnesses recently. if the ends of them break, do you just use the old wires and put a new end on? Or do the wires themselves degrade as well?Update
Still pulling things apart on the truck. Removed the radiator, battery, alternator, coil pack bank and steering rack.
Definitely worth removing everthing as there is so much room to work with now to remove the crank bolt so I can fix the oil pump leak. There also seems to be a small leak at the crank seal so doing that as well. Unfortunately the harnesses on this truck have bee problematic. The heat has made the plastic brittle and I have been breaking harnesses. The alternator harness completely disintegrated and the coil pack harness broke as well. Argh!
Good thing I have the part numbers for these...
Also, got the new power steering pump installed! Got the surface all cleaned up to make sure I had no leaks. Put a new o-ring on the new pump and went in no problem. Certainly easy to install without a radiator and alternator in there! Also, without any suspension or steering components there's tons of room to get my hands in there to clean it up.
Some news, my folks inherited an FZJ100 from a family friend that tragically passed away. He loved his 4wds and we want it to go to a good home to honour his memory. At some point I'll put it up in the 100 series classifieds for sale, but if anyone is interested in it let me know! 300,000km but lots of stuff has been replaced and long range sub tank to boot. 1999 model.
What's with the Phillips screws? Those OG?Back in Canada! And back to work.
Finally made some progress and starting to put things back together.
With the rad out, I wanted to tackle the oil pump gasket and crank seal. Which means removing the crank bolt. I jacked up the pressure on my compressor and it wasn't enough to budge the bolt with my impact.
So to ensure sufficient CFMs going through the gun I borrowed my buddy's compressor and teed the air lines together. Worked AMAZING. Removed the bolt instantly at the same pressure as before. Just some advice, best way to get your impact to work on tough bolts is to make sure you optimize your air flow rates.
Removed the oil pump and old crank seal. Cleaned up as much of the oil/sand mixture on the motor as I could. I sure was caked on there!
Oil pump re installed with new gasket and bolts
Then got the seal and crank back on. I found it difficult getting the key back snug on the crank enough to get the pulley back on. But I got it. Next step is to borrow a torque wrench that goes up to 305 ft-lbs!
