I soaked it for 24 hours in a can of Gunk brand carb cleaner. I'll see if I can find some Berryman's somewhere. Btw thanks for the great videos on youtube!What ever you have been “cleaning” it with ain’t cuttin’ it. Soak it in some dip type carb cleaner like Berryman’s ChemTool for a day.
Thx - I must've overlooked that...and take the cap off the idle mixture screw, so it will be a full cleaning.
Use a lubricant from here. Carb cleaner and carb dip are poor lubricants.
Yes, that's the plan, I just wanted to make sure there was no more gum in there. I'm planning to use some very light oil, do you have recommendation?Use a lubricant from here. Carb cleaner and carb dip are poor lubricants.
Thanks, There's no visible corrosion staining on the shaft, and it felt like it was gummed up, and now nice and smooth after finishing up with the carb cleaner. So I'm going to oil it and call it good.Bill- If you think there is rust around the butterfly shaft you might feed some rust remover down the shaft. Permatex Rust dissolver works great. It’s a pink gel, I believe it used to be labeled “naval jelly”. If you have a small butane torch you can heat the area to help draw it in. As I stated earlier, evaporust works good also.
REM oil is light and works good
