- Thread starter
- #1,821
A bit ricky as 74 could have been a linkage or cable carb. But I have both in stock.
Do you guys still have the FJ60 carbs in stock?In stock as of 11/22/2017
FJ60's
$270 shipped to the lower 48
If the button doesn't work try this link: Error - Cookies are turned off - PayPal
FJ40's & FJ55's mechanical linkage type (non throttle cable type) this is mainly for you 2f folks
Includes air cleaner spacer and choke cable stop.
$271 shipped to the lower 48
FJ40's & FJ55's with throttle cable type systems uses 1970-1973 FJ40 throttle cable. This carb can be used to retrofit those who have Weber or Holley carbs as well. If you have either of these carbs you will need a stock carb spacer.
Includes choke cable stop and stainless steel throttle cable bracket. You will need to purchase the throttle cable from SOR.com or Toyota ( SOR qty1 of part #042-04B-EC and qty2 of 042-34A)
$315 shipped to the lower 48
If the button doesn't work just use this link: Error - Cookies are turned off - PayPal
If you live somewhere besides the lower 48 I'll ship it just please PM or e-mail me for a freight quote.
Accepting paypal links above or directly to my paypal address marshall@828rugs.com or checks
Marshall Shepherd
500 Marsh Creek Dr.
Mauldin, SC 29662
Please note that checks will need to clear before I ship. Sorry for the delay.
New, brand new desmogged carb.
These are aftermarket carbs. I've been working on bringing these into the US for a year now. I have a product you will really like.
They also come with the high altitude jets (they reside behind the big bolts on the fuel bowl), the 9mm air cleaner spacer and the choke stop if needed.
The first carb below is the f carb with cable brackets. You will still need to supply your own cable.
2F with mechanical linkages both 40 & 60 series.
Should be all shipped outHey
I also ordered a carb and would like a confirmation. Thanks again!
Peter
Next batch in two weeks but it’s have sold already. Spring is coming.Do you guys still have the FJ60 carbs in stock?
Hi Marshall - Do you have rebuild kits for 2F carbs? Need new gaskets.
Tnx,
Tim
Sounds like a sticking accelerator pump. Do you have the return spring like shown in this pic? It's the silver spring.
