Kayaker
Well I just had an interesting experience: Went to crank up the LC, did all the necessary precursors - pump twice, choke out, gear shift in neutral, depress clutch for good measure and turn the key to the start position. 9 times out of 10 fires up as if it was equipped with fuel injection but not this time - oops, choke only half out. Return key to run position.
What the heck - starter still engaged and turning. Key to off - starter still engaged and turning. Off, on, start, off - still engaged and turning - I know: put it in gear and stop the starter. Ah finally; wait this may be a bad idea - depress clutch, starter still engaged and turning!
Out of the Crusier, pop the hood, grab a wrench - starter still engaged and turning. Off with the battery cable, now quite warm to the touch. Finally - blessed silence.
Never had this happen before - thank goodness I was home in the garage where I had quick access to my wrenches. After giving it some thought, I figured must be the solenoid. Took off the starter, removed the solenoid and the plunger and hook slid out of the housing - that doesn't seem right. Fortunately, Advance Auto had replacment solenoids for the stock starter. When it arrived I gave the plunger and hook a little tug just for fun and sure enough, stays put - just like I remembered.
After installing the new solenoid and replacing the starter, she fired right up, as usual and thankfully the starter disengaged when the key was turned back to the run position and off. Good ending to what could have been a bad story. Anyway, just for fun I dissected the old solenoid to see what happened. Here are some pics of what I found. Looks like the clip on the end of the plunger that keeps the relay contacts in place popped off - though I couldn't find any remains of said clip. Consequently the contacts stayed closed when the ignition switch was turned off. Never had that happen before. Hopefully I'm good for another 41 years before it happens again.
