I picked up a 78 fj40 without a complete wiring harness. Any recommendations on a simple replacement kit?
I purchased a complete wire harness from JT outfitters... Its still sitting here in the box while I wait for my tub to be delivered, but it looks very nice, each wire is labeled, coil cut off switch for security. In the neighborhood of $250
And doesn’t coolerman have the correct color coded wires for those that want to build full harnesses? I’m a ways off from doing my 75 but I was thinking that was the route I was going to do... even if the original harness seemed okay figure it couldn’t hurt to do a wire refresh.
Do you mind if I ask what you paid for your complete harness?I got a complete harness from @Coolerman and it is beautiful. I wouldn't think of using anything else.
Just came across this few year old post and wondering if you ever used your JT outfitters wire harness.? If so, how'd it go? I've got a 40 that I'm looking to dig into the wiring on and not sure if I should try to patch and piece it all back together or get a new harness. Can't seem to find many options out there. JT's is $379 and obviously not OEM. Wondering how well it fits and how much customizing it'd take. Any help you can give a novice would be a big help.I purchased a complete wire harness from JT outfitters... Its still sitting here in the box while I wait for my tub to be delivered, but it looks very nice, each wire is labeled, coil cut off switch for security. In the neighborhood of $250
I still haven’t used it… I ended up finding a parts truck(a73) and used the loom out of that…for my 71. . It wasn’t exact, but close. Back to the jt harness…..I’m now in the process of restoring the 73 parts truck and need a harness… so I took out the new 3 yr old loom. Looking it over… looks to be more of a generic hot rod harness then an fj40 (as it was advertised to be). Each wire is labeled, but for things like “EFI” or “Electric fan”, To be honest it looks like a real pain. No connectors so there will be tons of splicing wires onto existing push connectors…. Nothing for rear fan motor, just the things I noticed at first glance. As I said… it was advertised as an fj40 loom, but nothing more then a painless wire harness in my opinion.Just came across this few year old post and wondering if you ever used your JT outfitters wire harness.? If so, how'd it go? I've got a 40 that I'm looking to dig into the wiring on and not sure if I should try to patch and piece it all back together or get a new harness. Can't seem to find many options out there. JT's is $379 and obviously not OEM. Wondering how well it fits and how much customizing it'd take. Any help you can give a novice would be a big help.
Thanks for your assessment. I agree and am going to pass on the JT. Will dig in and see what I can come up with. Good luck with your project(s)!I still haven’t used it… I ended up finding a parts truck(a73) and used the loom out of that…for my 71. . It wasn’t exact, but close. Back to the jt harness…..I’m now in the process of restoring the 73 parts truck and need a harness… so I took out the new 3 yr old loom. Looking it over… looks to be more of a generic hot rod harness then an fj40 (as it was advertised to be). Each wire is labeled, but for things like “EFI” or “Electric fan”, To be honest it looks like a real pain. No connectors so there will be tons of splicing wires onto existing push connectors…. Nothing for rear fan motor, just the things I noticed at first glance. As I said… it was advertised as an fj40 loom, but nothing more then a painless wire harness in my opinion.
