My FJ 62 had some sort of HID system [Hella H4 shell] installed for the low beams and looks like they left sealed beams as the high beam. I left it that way for a while, but now i am having issues with one of the low beams [looks to be a bad ballast or controller].
I dont want to waste a lot of intellectual capital on them and just bought a set of trucklite LED lights and a new set of H4 pigtails to be able to wire them back in.
My question is this, because of course my wiring is all messed up for the low beams, how is the best way to approach this? I am trying t understand what in H4 connector needs to be "fired" to make this work.
I was expecting to take out the HID Controllers and ballast and Hella shells and just use the trigger wire going into the HID system to hook to a relay and use the relay to power the "low only" beam contact in the H4 connector, ground the common and be done.
Is it this simple ?
Is it this simple ?
