I just bought an 8274-50 here on Mud, but it appears that it may have a bad solenoid. The motor will spool out, but only clicks when I spool it in. I've cleaned the connections and still no luck. There is surprisingly little info on the Web about the newer 8274-50 wiring.
So, this issue would most likely be a bad solenoid, correct? If so, how do I know which one(s) it might be bad? There are four:
