94 ftlb or 127 N-M
IIRC the last time I weighed a later transmission/transfer case combo it was about 210 lbs., but that was an older FJ60 without the extension housing. I've got my H55f with split case hanging from my engine hoist in the garage, but no good way to weigh it.Bump
Have a related question. Had planned on picking this up in person but life has gotten in the way. Looking at gettting it shipped now. Figure some here might have a good idea of the weight of everything plus the pallet for a quote. Thanks
View attachment 1550132 View attachment 1550133
Where did you get the shifting instructions plate?
Are you planning on fabricating a transmission mount for the H55F?
Nope. Not needed. It's not going to be a rock crawler or even an occasional extreme Off reader. It's just for putzing around town.
Just picked up the 40 from Kibbetech. They built the cage which was welded to the frame. They also built the new seat brackets using the original seat legs. They also installed and welded brackets for the seats and harnesses. Their work is incredible. I guess for a group of guys who routinely build $150-200k trophy trucks I guess this is cake.
I’m still in need of a few items just in case anyone has something or knows where I can get these:
- 60 Series 4WD shifter
- Rear view mirror
- 5-spd Shifter knob (cruisercrap stop making?) found one: 5 Speed Shift Knob for Land Cruiser FJ60 or FJ40
- Speedo housing extension H55 (may just go to SOR and get one-piece cable: Page 180 Land Cruiser Speedometer, Gauges & Cables)
- Need 60 shifter plate with cutout then notched for the gas tank
- Reverse light connector
- Inspectioncover for 2F (need this ASAP)
