1993 Stock 278K No Locker. I am looking for expert advice on clicking noise in front axle while turning please. Slight vibration after tire balance. Goes down the highway fine at 80MPH. I've been told front axle overhaul with gasket kit, Front Diff Trunion Rebuild, not sure if this is the same job? Also, that axles may be difficult to remove and can be bent in the process. I am not a mechanic but I would like to understand where and why this noise is coming from and if I am looking at catastrophic failure if I continue to drive it. I need to replace front brake pads and it seems like I should have this all done at once. Price for this job and shop recommendations greatly appreciated( Colorado Front Range, Boulder-Denver ). THANK YOU!
