cruisedeisel
Toyota's for life
Nice 1st attempt.
I believe it takes very little pressure for the tube to stretch to the point it contacts and conforms to the tire carcass. I have had the tubes for about 2 years now and they have seen a fair amount of trail use including moab. If a tube does get a tear in it then you still have the tire carcass itself to prevent air leakage except for any pinhole leak in the bead lock ring which may slowly leak out. I coated the tubes with talcum powder b4 installing to help it slip initially into place as I installed it as a trick I found online from bicyclists and how they install tubes. The first 2 tubes ended up tearing though. I found out that with a new tube in a tire, you have to air it up to like 10psi first initially, then pull the valve stem core and let it deflate, reinstall core, then fill it to normal pressure. If this is not done then the tube can get a pinch in it and it will tear at full pressure. I found the tubes on ebay, they are agricultural tubes and are pretty thick(1/8" or so). I expect that at some point the tubes will wear out, but Im not really sure. If so I'll just install some new ones.No issue, I guess, with the tube wanting to "walk around" inside the tire when aired down so much?
