January 16, 2018 update/edit: Done with the Tundra front Suspension Swap and I’ve got results... BLUF: 1.25” front lift!
The front worked! But the rear shocks were too different.
See below for more updates and pics.
Original post:
Question and advice... it's about time to switch out the shocks on my 2010 sequoia's (limited/non air ride) suspension.
-When I had my 4th gen 4runner, I switched out the old suspension with a 2nd gen Tacoma's TRD bilstein front Coil overs/ struts and utilize the rear shocks as well. This is also known as the "taco swap" on T4R.org. Gave my front end a 1&1/4" leveling lift. I then utilized rear springs from an FJ cruiser that yielded a 1" rear lift. IMO, it was the most cost-effective and all OEM part Toyota lift I've ever seen.
(The taco suspension parts were given to me and I bought the rear FJ springs for $50)
-Is this same concept possible with a 2nd gen tundra's suspension on a 2nd gen sequoia? Front Coil overs /struts and rear shocks?
-I've looked on forums like tundra solutions but no dice.
Any input or advice would be really appreciated!
Ps, this is what my 2004 T4R looked like after the taco swap. Not bad really for $50.
Original post:
