gtfour43 said:Should be easy to spot with that much play. Does the truck wander at speed? I would fix it asap or your tires could take a beating on the road.
It will stay straight as an arrow on the highway at 80+. It does not pull during coasting, cruising, nor braking. Under acceleration it pulls quite good (straight is 12 o'clock normally. Mine is 10 o'clock to keep straight). I think the 4wd is pulling the front passenger to the right. and causing me to counter steer so heavily. If I hit the gas and counter steer, then dump the throttle it will stop pulling. I have tried swerving through a empty parking lot trying to feel or hear is something is loose , bad way but it makes sure ABS and trac work, anyways, when I got aggressive I felt worlds of play. The front end had very bad pull and a heavy dead zone. Any gas she pulls right, no gas or braking and straight as arrow....
