ewillis
So I have the truck at Toyota in Claremont. 1994 80 series with 124K. Speedometer and odometer stopped working. Truck will stall at low idle usually when braking at slow speed and OD light is blinking. Figured it was a speed sensor, but not wanting to purchase an expensive part and it not be the case, I just dropped it off at dealership. I did not pull the codes prior to dropping off. Tech working on the truck has a 1996 80 and swapped the sensor into his truck and said sensor is good. Tech is a "cruiserhead" but I don't know him personally.
Service rep said tech swapped cluster into his truck (not sure if this is possible given the different years 1994 vs. 1996) and said cluster is bad. The tech said something else besides the cluster must be faulty, but not sure how he came to this conclusion and is super expensive to start going through electrical system.
Long story short, I can't find a new cluster for sale (not sure they even are for sale). Dealership said discontinued. Need some advice on what the problem could be and if anyone knows of a cluster source.
As always...TIA
As always...TIA
