Received both the fob and the replacement key. Both were easy to assemble and are a great product!
I've broken 4-5 of the stock fobs over the years. Ordered and thank you!
Put mine together today and have a question. I have he ever so slightest gap on the side between the top and bottom shell pieces. It is slight but I can squeeze the two together to eliminate it but can’t really torque the screws enough to fix. Anyone else seeing this? Lastly, the kit came with several little pin looking pieces. The assembly video does not address them. What are they and are they required for something?
I have never broken an oem key fob, but nevertheless I see the improvement in these and any improvement to my LC is worth it so I ordered one last night!
1. For the gap: post a pic if you can. With all the keys I've tested there is no gap at all as far as I've noticed, but I wonder if you've got a thicker key or something. Post a pic and let's see what's up.
2. The pins are for the "I" style key blade and are used to hold that style in place firmly. If you have the common T style, then you can toss those pins in the trash! It's a small cost I eat to make sure most of you have a working solution when you open the package.
I think you'll find it money well spent.
I'm not sure if this is an error on my end or not, but I cannot see the image and it appears the image URL is broken. I tried to view it in FireFox and Safari. Again, not sure if it's a problem on my end or not but hopefully others can chime in stating if they can see the image.Here is a photo of the space. Again, I can squeeze the two together more or less however the nuts are as tight as they can get w/o probably ruining them.
I got mine and finally put it together yesterday. This morning my wife went to move our truck and asked for my key. As soon as I gave it to her she was like, "where did you get this?!?". She loves it. I suspect I will be ordering a second... Just need to pick colors!
@PabloCruise any chance you'd consider stopping by so I can check this thing out in person?
@suprarx7nut I have this too. Mine squeaks when I squeeze it as well, not sure if you can hear, or see it, in the vid. Not a huge deal and doesn't affect anything, nor am I complaining and will still be ordering another...but maybe worth a look. Btw thanks for the extra screws!
