wondering why there is no information on part timing a 200 series. they make kits for the 80 and 100 series so why not the 200?
TIA
TIA
i'd do it for the doughnut factor - the 5.7 has to whip that tail around like a rag doll
1. Wouldn't help unless you disconnect the rear drive shaft too.
2. Locking the center diff would have the same outcome as far as getting off of the trail.
It'll always spin. You need to remove the CV shaft otherwise it'll flop around while the front diff does it AWD thing and/or wheel spins the shaft by it's turning. If you have a snapped CV, you can remove the CV shaft and CV joins, keep the ends in the diff and spindle to keep the bearings and fluids from douching out, lock the center diff and be on your merry way. This was the plan when Patrick snapped his CV in Moab but we couldn't get the CV joint out of the ends due to them being pressed Tundra axles. The LC CVs are held in by clips so they just pop out.
Ah ok. I was thinking if you had manual hubs you could unlock them and they'd spin freely so the shaft wouldn't rotate at the wheel, and based on the Marks 4WD doc on the 100-series by pushing the "new" CDL button you'd unlock the front diff and thus the shaft sticking out of the front diff wouldn't spin either.
