Living in the Past
I should've clarified that I would search for a 70 series FF rear with integrated parking brake.
I have both semi and full floating 40 series rear axles with parking brakes. The US never saw any full floating rear axles in a Land Cruiser until the 80 series. If you didn't want to keep the offset and 9.5" diff with the correct spring perch 8/80 semi floating 40 series axle is all that was available in the US.
Everything else has either been modified or imported used from another market. Only advantage I could see is some of the layer 70 series had disc brakes and parking brake. Width is close enough only need to move spring perches. Don't feel the need for rear disc brakes so full floating 40 series is the easiest option.
