To preface, I'm very new to - and unfamiliar with - 24v systems and a bit of a dunce when it comes to electrical.
I just brought home an HJ61, and one of the first things to go was the old, beat up Walmart-special cd player. I installed the shiny new Pioneer bluetooth player and everything seemingly works great. However, I realized after coming back out to the truck to work on some other things, every time I start it up the new head unit takes me to the initial setup screen. After some troubleshooting I figured out the problem. The 24v ---> 12v converter that was installed by a previous owner (ICT Industrial Power Series 10, a 10amp model) only receives power when the ignition is switched to ON.
That leads me to some questions:
1) If I were to give the converter constant 24v power, would I be able to install some sort of relay/switch so that most accessories that need 12v only get it when the ignition is switched to ACC or ON? If so, is there an example of how this might be done? I may not the brightest when it comes to electrical, but show me how it's done and I can figure it out.
2) If I were to give the converter constant 24v power, would I be having battery drain issues? Even if the only thing connected to constant power is the head unit? i.e. Does the converter itself draw power?
3) Is the above mentioned converter ok? It seems like this one's been kicking around back there for quite some time powering the previous CD player as well as a triple cigarette lighter dock, that currently charges a couple of phones at a time, at most.
4) Should I ditch the converter and run a third battery, with something like this? Is there a cheaper, but still solid 24v ---> 12v charger out there?
Cheers!
Cheers!
