- Thread starter
- #101
I have to put a crankcase in a unit do I will snap some pictures for you.
did you know Stihl made 3 gaskets for the 009 ,View attachment 1487516 Before serial number X 12 725 131 use crankcase gasket #1120 020 0500
After serial number X 12 725 131 use crankcase gasket #1120 020 0501.
From serial number X 14 194 817 (on 011) use 1120 029 0502.
I agree, I can see at least three different case/gaskets in this thread.did you know Stihl made 3 gaskets for the 009 ,
Thanks for checking in Dan.Pacer
Two things can be happening.
The ball can be “stuck”. This can be caused by the oil simply sticking thing together.
When you remove the ball and spring, is the ball pitted? If it is, it is leaking and it will not activate the plunger rid of the diaphragm.
