Nah, all the airflow will suck the cruiser forwards like a jet engine!
Why would and aluminum radiator solve your problem? The only reason OEM's went away from brass/copper radiators was to save weight. Copper transfers heat with near twice the efficiency of aluminum.Insufficient air flow still persists, roaring is just sorry, startup is weak/quiet at low rpms then jumps up after a few seconds. I am now on my third fan clutch. It's been overhearing almost every time I slow down or idle now that it's over 100. Also the idle jumps up and down like it's starved of water, going from bout 400-1100. This also happens at startup sometimes when AC is on. I am at my wits end here, poored almost 2k into this pos and might have to sell it. My plans as of now are to try heavier fluid and if that doesn't work buy an aluminum radiator.
Hmm. Don't know, shop didn't mention that. Valves were adjusted. What is that
Come to think of it, I did bring it back after 500 miles but I thought that was for the valves. They must have taken care of it.
Timing was done. What other external components are there?
The fan just isn't cutting it. When I was on the trail last week the fan on my buddies rubicon was throwing up dust, and it sits pretty high. My fan will hold a rag on the front (when the idle kicks up)but not even close to throwing up dust.
You can easily see that your friend is wrong by googling the subject. A very efficient aluminum radiator can be built but it will be a custom build. The issue is that you have a certain sized space for your radiator and going aluminum will gain you nothing if not make things worse.I don't have a digital thermometer. The gauge goes up almost to red before I have to shut off/drive/turn off AC. A trustworthy friend mentioned aluminum radiators are more eficient in cooling and I believd him. I just can't understand why the damn thing will not stay cool and am willing to try anything. Apparently OEM fan clutches don't work so I'm going to be tackling that first
When it's overheating the fan clutch should be fully engaged......I've seen plenty of bad Aisin fan clutches right out of the box. FWIW each was from Amazon
