Cruiserdrew
On the way there
@Robert Franzke
I basically agree with your assessment. Especially the way the interior smells. Sun bleached vinyl, long lost french fries, dust and gear oil. You will find your dog will love the car and rides will always be a treat.
It gets more road friendly with a 5 speed if you are inclined, both at the low end and at the high end. It won't make it faster uphill. I've taken mine over Tioga Pass several times, in literally 2nd and 3rd gear, pulling over into every pull out to let the line of impatient people on vacation go by.
My only caution is to accept it for what it is. If you try to pass, or rev the motor, it won't last and you'll be stressed and unhappy. Don't often go above 3000 rpm. I know the tach says redline is 4000, but that's very optimistic. For highway cruise 2500-2700 is about right. It was built to go about 55-60 on the highway. Keep that in mind.
With a decent suspension, it rides well and corners like an old pick up. Adding a rear sway bar off an FJ62 is a good idea and cleans up the body lean.
The fuel gauge is wonky. There is a voltage regulator in the fuel gauge the gets cranky and both the fuel gauge and temp gauge give unexpected readings at the same time. This is normal. Replace the fuel gauge if this happens to you.
Check the oil a lot. Like every fillup until you get a feel for it. Use a decent oil of the 15w-40 or 20W-50 variety. View one of the many oil threads for ideas.
Enjoy. I got my 60 originally as a lark and here 15 years later, I still have it.
