rkymtnflyfisher
Trout Bum
It snowed like crazy here today, yesterday was 70*, all we got was a muddy mess.
Soooo....you owe me about 5 hours. A morning well spent. Beautiful, just beautiful. Thanks for sharing
@cruiseroutfit
Kurt, I have been planning the steering column (older 1 piece) and think I have it under control.
I am going to cut the inner column as long as possible and install rag joint adaptor at the correct length.
I can use the bronze bushing or the bearing to center the inner shaft at the end of the outer column housing. The firewall mount gets the bolt holes drilled and is welded to the outer column. I'll probably use a piece of weather tech mat to fit between the plate and firewall.
Do you have any pics or recommendations on how long the outer column housing should protrude past the firewall? How do you recommend fastening the bushing or bearing at the end of the outer column?
Thanks,
Jesse
Let me know if these help. Can take more if needed.
This is from my 71
View attachment 1430602 View attachment 1430603 View attachment 1430604
Thanks a ton UpperBlack, does it look like they are about 16ga?
That should do it. Thanks again!Yes they do
If you want any other pics let me know I'm right by my rig
