bagochips76
So I have a 76 FJ40 that I am having an issue with. I can't get it to turn over. I have checked and replaced the following:
- Starter has been bench tested and is good working order. The Solenoid engages and the motor turns when bench tested. The solenoid engages but the motor does NOT turn when mounted on the motor. I have tried two other known good starters and am having the same result
- Battery has been replaced with a brand new one
- The positive cable from the battery to the starter has been replaced with a new one
- I have added a second ground to ensure that it is properly grounded
- The engine turns freely; it is not seized
- I have bypassed the ignition switch with a remote starter switch - same result.
I have had the truck running and have even driven it. The last time I took it out for a test drive it was doing fine and then as I was driving the truck just straight up died on me. It's almost as if the electrical power just cut out on me. I pulled over to the side of the road and tried to restart it. Nothing but a click from the solenoid as it engages the flywheel but it will not turn it.
The engine fuse in the fuse block is good.
Some other items about this truck...the motor has been rebuilt by someone other than me when the PO had it. Have been cleaning up their mess. The block is a later model with flat top pistons and the head is an earlier model that appears to have been decked as it does get good compression. I had it running like a top but while I was getting running, I had the same issue with the motor not turning. I got it dialed in and got it to turn and start after I replaced the battery and cables. Now it is giving me the same issue that I was having before the new battery.
Has anyone encountered a similar issue?
Thanks in advance for any help and input.
