Wow. Incredible pics Handsel.
Much appreciated, Onur!Wow. Incredible pics Handsel.
I made a tool similar to the one Georg at Valley Hybirds uses. His is a standard drum brake tool, cut in half, with 'T' bars welded onto them. Not having a welder anymore, I took a brake drum tool and simply bent it 90 degrees to allow radiator clearance. If you look closely at the cup end, both sides are ground flat, which allows the spring to slide off cleanly. Makes the tensioner spring R&R very easy.Just attaching the new tensioner spring took about 1 hour alone.
gotta love how accessible the timing belt is on these 1HZ s hahah every other engine out there you gotta take the whole dang front end apart to get to it. Well done brotha!
Just attaching the new tensioner spring took about 1 hour alone. Holy $hiT that thing is a serious pain the ass!
Ih8tensionersprings..
I actually used a few tips you gave in a really old thread, so thank you. Mainly putting the trans in 5th and making sure e brake is on hard before taking off the old belt. Your comments in that old thread gave me confidence to tackle it.I use some electrical wire looped through the hook on the spring. I tie the electrical wire to a handle (screwdriver works)
Yep. I got some made for j**ps in the US with the proper aim \__ \___When you replace your headlights make sure you get lhd ones
Thanks man, It's coming along !Looking good Handsel. Those beach pics are fantastic! Big improvement with the ARB bumper. Loving your troopy!
What headlights did you go with? I gotta swap my RHD headlights out too but haven't decided which ones to go with.
