The clamp type splices are ok if you can keep them completely dry. The problem is with just a bit of moisture, the often "thin" connection between the metal blades inside and the wires gets corroded and the resistance goes up, sometimes to the point of failure. In an automotive/trailer/boat/orv/snowmobile/etc environment I always vote for crimp-type connections and heat-sealed wherever exposed.
