whitey45
- Location
- United States
I will take the two latches. ThanksPM was sent to you.
Payment was sent for the latches.I will take the two latches. Thanks
I may need the brackets and wiper switch? I will check the amView attachment 1426727 Drivers seat brackets, good shape $45 shipped also early 40,45 wiper switch($65) shipped and windshield latches $50 shipped
These brackets are correct and do not mirror each other as the seat was designed for easy removal sliding it sideways out of the brackets. Check your bolt pattern, these should fit.
That is correct, they should be the same and mounted the same, so that pin can be removed and the seat slid out of the brackets. Just wanted to point out that they were the right height for early 25's and too tall for later ones or 40's.
Not sure about your mounting, but these are genuine 1959 fj25 seat brackets!
