guardcompany
Shea
Christmas morning from the wonderful people at Slee...
Do you have part numbers? Front and rear, same numbers? Thanks
Those are some sweet looking beads.Making some progress on my @4x4labs rear bumper attachments.
Neither of my cupholders were cooperating...front cupholder lid wouldn't close and the rear cupholder wouldn't open. So I went ahead and removed the center console to see if I could fix it and found this:
Good to know that if you put something inside the cupholder and close it, it is very likely it won't be there again when you open it.
I looked back at your clean, clean, clean cruiser and say paint them the same grey tone you have on the bumper trim. My thinking is it will show up in the shade of the wheel and yet be different than the more silver of the wheels........ two cents provided.Took her down the road last night for a good workout, let her stretch her legs then stopped by my friend's shop to talk about brake caliper paint... naturally he said "red" but I don't think it'd look right on Elsie... Been trying to decide what color to paint my front calipers as they look pretty terrible even though they're only a year old!
View attachment 1426682 I am on my second key, both have broken into 2 or 3 pieces over 6 years, usually when I lend my cruiser to my brother or father...
I also had 2 spare keys cut, one for camping in the middle of no where that I cable tie to a place under the cruiser that I can easily find but that is not easily seen, and not near any moving parts... but when camping and packing away the tent I forgot them in the tent pocketand fully loaded cruiser with keys packed away ... sent me underneath to retrieve my 3rd key...
The other I have been using till I get my main set sorted... I usually clip my keys to my belt clip... that got caught and ripped the belt clip today and my keys fell to the floor...
After that I could not start the cruiser and even after locking and waiting 15 mins a couple times I still failed...
I think the little chip broke inside the Lexus key... My spare camping key is no where to be found so the cruiser is parked on the farm
Is there keys out there that are as tough as the cruiser??? Anyone else have these problems?? Any one have a solution?
Looks like it's time for some 35s...Finished the front end work I've been putting off for a while now. I reindexed the torsion bars, installed the OME Torsion Bar Reinforcement Kit, then cranked the tbars to compensate for the 2" springs I put in the rear. I only got to drill the first hole on each side for the reinforcement kit before I called it quits. Those lower control arms are tough to drill through and laying on your back drilling upwards is tiring since you have to start with a small bit and eventually work your way up to 10mm. I then had to took her out to stretch her legs of course
Funny...I was thinking the exact same thing But on a serious note I do need to upgrade tires in the near future. I have a trip to Colorado planned for early August so it will definitely be before then. I just need some more rubber to fill out those wheel wells now that I got the room!Looks like it's time for some 35s...
Thanks that looks do able!Broken key solution:
Home - Eternity Key
Suddenly won't start with a good key:
EFI Relay Bypass Kit (Immobilizer Fix) for UZJ100/LX470
