- Joined
- Sep 26, 2003
- Threads
- 117
- Messages
- 11,207
- Location
- Lancaster, Ohio, USA
- Website
- www.tlcperformance.com
@FJ40Jim , is there a way to adjust the valves on a cold engine? The FSM outlines the procedure on a hot engine, but I'm starting from scratch. Also what are your thoughts on exhaust manifold vs. headers. I noticed that you are running a header on your 60.
It's a fresh engine (sorta), so just adjust valves to spec. After the engine is fired & run for ½hr, then it's time to retork manifolds, headbolts, and adjust hot valves to spec. These engines are very homogeneous, so the valve lash doesn't change much with changes in temp.
Headers can give a small bump in efficiency, but they also introduce their own problem set. More heat radiated in engine bay, leaks due to flimsy flange, leaks due to differences in thickness WRT intake manifold, etc.
