I personally would check the condition of your injectors and compression. if you have good compression and injectors are firing the way they should check back with an update and we can go from there.
No codes now that it's running again? Sounds like a throttle position sensor to me. But I'm still learning with these big turds still....
Yeah that's very possible run it for a while and see what happensSo it turns out some silly man out leads 3 and 4 on backwards. She now runs, but is blowing smoke out the exhaust - it's not burning oil, so I'm hoping when the incorrect plug gap 'sooted' everything, it's just dumped a heap of s*** everywhere that I have to burn off.. right?
Smoke is gun, cruiser is running like a dream on gas, not so much on petrol but good enough for now. Thanks heaps for all the help guysYeah that's very possible run it for a while and see what happens
