- Thread starter
- #41
I'm chasing the same thing right now, except one morning when I fired her up it just wouldn't hold idle. No braking issues, no recovering as it dropped, just straight to dead once off the throttle, every time, 100% repeatable condition.
I replaced the PCV and VCV with grommets and hoses today, and that definitely needed to be done as some of the hoses and the grommets were brittle. But it didn't affect anything. So I have an IAC on order, which I got for $150 so not bad and hopefully that's the fix.
I'm too lazy to look at the FSM right now - what's the gasket for with the IAC since it's a plug in component?
The IAC uses an "O-Ring" not a gasket. The gasket in the post is for the Oil Level Sensor (OLS) that I now need to address.
For your '95 you have the less expensive/easier to locate 22270-66011 IAC. Seems like we few folk who have the '93-'94's get to have the more rare and more costly parts for the same motor.
As strange as it seems don't forget to look at the hose/check valve/grommet on the brake booster and the booster itself for possible vacuum leak areas.
Tip for changing your IAC. Use a 1/4" drive ratchet with a 12" extension, a 1/4" short socket and a #2 Phillips (crosspoint) bit in the socket. The extension will give you the reach over and back to the lower screw and by using the ratchet you can get enough pressure in on the screw to keep the bit engaged in the screw and the leverage to turn it free. I placed a small neodymium magnet on the side of the socket to make sure I did not lose the screw or bit down the black hole under the IAC.
