- Joined
- Feb 10, 2002
- Threads
- 550
- Messages
- 44,823
- Location
- Canton, Mississippi
- Website
- www.seeandeatms.com
Yeah that's a pretty common way to get more light in there
Hey guys.
I am going to install a new @Racer65 cluster into my 68 FJ40.
My harness is completely toast so I am wiring everything individually as I add it back.
My alternator is an internal regulator for an FJ60 on a 2F
So, what would be the proper way to wire the 50 amp gauge from the later model Cluster to my alternator? I don't have a fusable link anywhere so I'd rather use a regular fuse if possible but will buy whatever I need to make it work.
Yes, that's (part of) the original wiring diagram.
I got my new cluster and have a simple question.
Instead of running new power to my 50 amp gauge as described can I just replace the 50 amp in the cluster with my old 30 amp?
Also my old truck does not have the wires that go into the round pin plug. Anyone have an old plug they can send me so I can wire up the lights?
Temp guage is seemingly dead. Needle is all right. Does not move.
Don't you think the issue is that I have a 1984 FJ60 sender going to a 1968 guage? I bet the proper sender and it eases right in
Yes. As I said before: gauges and senders are a set. You can't mix them up.
Rudi
