I'm looking into upgrading the stock headlights on my 1998 100. What options are available aside from going to the 2003-2006 headlights and grill?
Thank you,
Thank you,
HID old tech is old tech. HID new tech is about as good as it gets. I'm running a TSX retrofit with morimoto components and Phillips bulbs set up at 35w. Immediate warmup, we're talking 10s or quicker. Crazy long lifespan, and I enjoy the warm headlights in the snow and ice.HID is old tech. Slow warmup, Low lifespan, Gets hot, Still has filament which reduces durability. Led is the way to go! (more lumens). However, because of the housing the beam pattern is not as "full" as HID
IncorrectHID is old tech. Slow warmup, Low lifespan, Gets hot, Still has filament which reduces durability. Led is the way to go! (more lumens). However, because of the housing the beam pattern is not as "full" as HID
Sounds like your fears are based off a cheap eBay 55w setup. As long as you go factory components or better with an HID setup, you will not be disappointed. But I will state I only approve of HIDs in projectors or approved reflector bowls.
LED tech is advancing like crazy and I believe it has endless potential. However after trying several different branded bulbs in several different vehicles, the output still isn't there for me for plug and play systems. Ive always been OCD about my lighting so I've tried about every different setup you can imagine, and the HID in a quality projector always wins.
Maybe a bad source for info? LED vs Xenon HID Headlights - Which Are Better? - LED Headlights ProFilament? On HID?
I thought by definition HID creates light by "arcing" between 2 tungsten electrodes.
Used a similar set and the fans were junk. But like I stated above, I have been disappointed with every LED bulb I've used.This is the kit I got: 9006 HIGH OUTPUT LED HEADLIGHTS LMZ PLATINUM 25W
Correct me if I'm wrong but doesn't the projector retrofit require a bit of cutting on the housings? What if I don't want to do that? Is it really worth it? My friend has an HID kit don't know which one. His beam pattern was clearly better than mine, but I felt mine threw light further. I will do more comparison.
Biased chart to sell product. Looks like they're comparing the worst HID setup with the best LED one.Maybe a bad source for info? LED vs Xenon HID Headlights - Which Are Better? - LED Headlights Pro
HIR upgrade would be great! I'm not sure why it's not done more, though I cannot speak as I have a LX.Modest upgrade compared to a good HID setup, but does nobody bother with the HIR Phillips 9011/9012 bulbs like the 80 guys do? Really popular upgrade on the 80 side. I have a set in the garage waiting for a bulb to burn out in the 100. Even with the stock set-up, the lighting in the 100 is so vastly superior to the 80, I haven't been that motivated to change anything.
I'm sure @spaber05 will chime in, but I'll go ahead and give a vague answer. The outside "lights" that you are seeing is LED accent lighting. The middle light is the actual HID beam on in the projector. The LEDs match because they are running lights and I'm assuming he wants to show them off. With the projectors on however, they're so bright that you can't really distinguish a color from the beam.
That looks good! Is the center bulb a different temperature? Or is it just the camera not picking up the proper colors? I would hate if it didn't match.
This has been my other issue with LED bulbs. Last winter I had to swap in a pair of halogens into my dads rig because his lights kept icing over. New OE LED housings have warmers in them.If you live in snow belt, LED's aren't hot enough to melt the snow so you have to stop and clean your headlights as your vis gets worse.
