Ok so I bit the bullet and bought a 1HDT and in the next few weeks it will be replacing the 3F thats currently in my 60.. I'm not doing it personally but I need to make sure that I get the correct parts necessary. Luckily my vehicle came with a H55F as standard. I got the correct bellhousing as part of the deal with the motor so that's sorted.. My questions are all surrounding the input shaft and clutch.. From reading these awesome threads I've got heaps of info.
https://forum.ih8mud.com/60-series-wagons/81067-1hd-t-h55-split-case-into-60-a.html
https://forum.ih8mud.com/diesel-tec...55-into-fj40-some-questions-some-answers.html
I just want to put it all together here in simple terms and hopefully someone can tell me if I've got it right or wrong as one or two areas are still a little grey for me.
The input shaft gets exchanged for the longer 21 spline shaft. An Isuzu 300mm clutch plate gets used with a 1HDT flywheel and pressure plate. I'm not sure on the release bearing and fork though.. are these also 1HDT parts? Any other peripherals needed here?
Alternatively the 1HZ complete clutch can also be used, this is a 275mm unit though, surely with clutches the bigger area the better?
Are there any other odds and ends that I will definitely be needing? I've got a couple of weeks to get everything together so any input or pearls of wisdom are much appreciated.. it will all help to get this thing done as smoothly as possible..
