I asked a local engine reconditioner here about it. He says there are 2 cams for the 2H and one can be ground to suit the 12HT cam profile.
He said he could only tell which one was suitable by measuring it.
Thank you Ross. I may have to go this route if I can not locate a 12HT cam soon.
Anyone got any suggestions for a supplier of the 12HT cam?
roodogs?
roodogs?
Personally, I'd run the 2H cam. I don't think you're going to miss too much.
~John
There are lots of 2Hs around that are running valves set to looser than that...I think you would as there is about 40 thou difference in the cam grind
