80 GPS Mounting / Creativity Needed.
КАГІҒОЯИІА
This may be an outfitting question but this relates specifically to an 80 dash so I thought I might try here first.
If it must be moved, then so be it.
I just bought this gps...
http://gpsnow.com/gmmap378.htm
Now, without drilling into the top of the dash, any ideas on mounting?
Has anyone mounted one of these or similar?
I thought maybe just behind and below the rear view on the window but seems a little cluttered.
The base is a little too large to go down on the shifter console.
Input would be greatly appreciated.
:beer:
That's a nice unit! I have mine mountedon the glass down towards the dash with a suction mount (Garmin 3600 IQ) so I think it is smaller than yours. I have tried it in various positions but I keep comming back to the lower part of the windshield as it is easier to view for me and doesn't block my high vision. I had it on the sun roof (inside)for a while and it worked great till I got the full roof rack. Then it blocked the reception. The weather option is really nice on yours, I've never seen that before.
I used a piece of metal wire hooked to the louvers of one of the air vents...
Bull - what are the extra's on the factory map light console?
Well.. if you don't smoke, or use the ashtray.. here is the solution I use:
Really simple, 2x4 cut, carved, and painted to fit all the way into the ashtray mount.
bull- that's a pretty slick install! Do you know what type of detector that is? Valentine One remote?
Yep, but its not that difficult. You do have to extend the monitor ribbon cable about 2 inches but its easy enough. You can look at the inside and more details on my sig line below. Go to 97 FZJ80.
G
I flipped it because I am anal and I liked the fit better when it is flushed against the roof. It also didn't hang down in front of the mirror. I see you changed the mirror so you obviously did not have that problem.
G
G
While you were in there you should of flipped the button rubbers to read right side up.
Looks slick! I like it
