I am installing a new steering wheel from metric TLC. The wheel looks just like my original one. I am following the FSM and have searched here on MUD.
Problem: When I tighten the center nut for the wheel to FSM torque (25 ft. lbs) the center spiral cable (aka clockspring) does not following with the wheel directly when turned. The center spiral cable will sit in place (not turn) for several degrees as the wheel turns until one of the plastic cable connectors on the spiral cable hits the side of the steer wheel frame...then the spiral cable will turn. This action appears to squeeze the CC and horn wires inappropriately. I have re-installed the steer wheel several times and played with the spiral cable and environs, with no resolution. The spiral cable is centered per the FSM.
Can anyone tell me if the center spiral cable is supposed to turn with the wheel 100% (no play) once the center nut of the wheel is tightened (and air bag is not yet installed)?
I have played with the black plastic ring that is on the very inside of the center spiral cable...this has not changed anything per my issue.
I am about to try my old wheel to make sure of any possible wheel differences. I have yet to install the steer wheel pad...does this affect the spiral cable per my issue (I see no tabs or screws for them to affect each other)?
Thanks, Jon
Thanks, Jon
