Of course it's hot here, (triple digits). Vehicle 92 FJ80 Getting ready for a long trip and need AC desperately. Any help or ideas would be greatly appreciated.
Started this thread a few days ago https://forum.ih8mud.com/80-series-tech/497996-ac-fuse-power-source.html. Still no worky.
Symptoms and overview:
No power to AC Compressor clutch.
Compressor functions fine if 12v is applied from battery (blows cold).
Had no power to AC fuse and placed a jumper across the sensor harness that goes to the evaporator. Now I have AC fuse power.
Removed and inspected AC amplifier board. Looks fine with no burnt spots.
Checked AC switch operation. Relay on amplifier board clicks in and transfers power from yellow wire with red stripe to yellow wire with red dashes.
Low pressure switch has been previously bypassed.
Vehicle now has no idle up when AC button is depressed. Vehicle takes longer to start now since this happened.
2 other sensors that I've read about may be to blame. I think one is an engine temperature sensor and another is a neutrual safety switch or starter cut off switch. Not sure where these are at and if they could cause the problem I'm having.
Thanks,
Steve
Thanks,
Steve
