So I did an OME J-spring and L shocks all arround lift!
I thought I had all my bases covered and read many treads trying to gather all the information, but I obiously missed something:whoops: The truck handles horribly, I'm affraid to take it on the freeway even with the caser correction installed, both front and rear DS are grinding, but that's to be expected I guess, I am taking it to Arizona Driveshaft and having them give me their diagnosis for both, I already tried to diagnose each by removing and locking the the CDL, both do grind badly!
My issue is more with the handeling, still very much wonders all over the place, much better after the yellow caster correction bushings, but still very unacceptable, rear end wonders a lot And it feels tippier turning right than left, I am hoping the install of the Rear Panhard Rod Drop Bracket Kit will fix this??
Under braking, the steering wheel will turn counter clockwise if not held, And well overall the truck is scary to drive!
Info:
97 FZJ80, 230K miles
Weight wise: Roof rack + Cargo Box (Heavy in rear) + M1 Battery + Stock front and rear bumpers, ARB Winch bumper + winch in near future + Rear tire carrier in the works.
Lift Wise here is what is installed and what I have ordered but no installed yet!:
MAF
4+Plus Proportioning Arm Bracket (installed)
4+Plus Rear Panhard Rod Drop Bracket Kit (Installing this weekend)
IPOR
Front Sway Bar Drop Kit (installed)
Front Bump Stop Drop Bracket (installed)
Rear Bump Stop Drop KIT (installed)
Rear Sway Bar Drop Bracket, PAIR (installed)
Staniless Steel Extended Brake Line Kit (installed)
eBAY
2" Alum Wheel Spacers (installed)
ToyTec Lifts, LLC
OME-850J HD front coils (installed)
OME-863J HD rear coils (installed)
60070L Front shocks (installed)
60071L Rear shocks (installed)
SD24 Steering dampener (installed)
CA77B caster kit (installed)
MAN-A-FRE
REAR SHOCK ROCK PROTECTORS (installed)
30mm Coil Spring Spacer Front (not Installed)
Please help me set this lift straight!
What am I missing to make this drive right???
Can I add MAF Caster drop brackets in addition to the OME yellos already installed to help with the caster?
Before anyone asks, nop I was a dumbass and forgot to take before and after lift measurements, but it looks like I got at least 5" of lift on the J's as compared to my 13 yr old OEM coils!
Info:
MAF
IPOR
eBAY
ToyTec Lifts, LLC
MAN-A-FRE
